- Bremerton, Washington
- Master Electrician
Butterfly™ Magnetic Wire Puller
Step 1. Release the cable from the spool and feed the magnet that is attached to the cable through the void or space through which you need to run your wire. Step 2. Attach your wire to the metal ring on the end of the cable. Step 3. Connect the magnet to the cable and wire and feed it with...
butterflybrandinc.com
