LECTRICBOSS
- MOORE, OK. USA
I HAVE INSTALLED A SIEMENS 200 AMP THREE PHASE LOADCENTER IN AN OLDER LEASE BUILDING. WE INSTALLED AN 8' GROUND ROD AND TIED TO BUILDING STEEL. THE PANEL ALSO CAME WITH 2 GROUNDING BARS ATTACHED TO THE BACK OF THE CAN WITH MACHINE SCREWS AND THE MAIN BONDING JUMPER SCREW THAT IS ATTACHED TO THE NEUTRAL BAR THAT IS INSTALLED WHEN THE PANEL IS THE MAIN SERVICE ENTRANCE WHICH IN THIS CASE IS THE MAIN FOR THE BUILDING. OUR INSPECTOR POO-POO'S THIS MAIN BONDING JUMPER SCREW INSTALLED INTO THE BACK OF THE METAL PANEL CAN SAYING I MUST INSTALL A #4 CONDUCTOR FROM THE NEUTRAL BAR TO EACH GROUNDING BAR, PROVIDE AN ADDITIONAL GROUND ROD AND THAT THE BUILDING STEEL WOULD NOT BE CONSIDERED AS A GROUNDING ELECTRODE (THE BUILDING IS A STEEL BEAM AND STEEL BAR JOIST BUILDING). NOW I CAN SEE WHERE THE BUILDING STEEL BE MIGHT NOT BE CONSIDERED BECAUSE WE DON'T KNOW HOW THE BOLTS WERE ATTACHED TO THE FOOTINGS SO BONDING WOULD BE APPROPRIATE AND WE WOULDN'T COUNT THIS AS AN ELECTRODE ALTHOUGH I HAVE NEVER SEEN IT TO BE A PROBLEM HERE. ANY THOUGHTS?
