Main bonding jumper
hhsting
Glen bunie, md, us
Junior plan reviewer
I have 11 sets of 750kcmil Al conductors going into 3000A main service switchboard.
11x750=8250 kcmil
8250x0.125=1031.25 kcmil
The plans the main bonding jumper of 2 sets of 600kcmil Al which would yield 1200kcmil Al total since they are in parallel
So whats the problem?
I thought the main bonding jumper need to be unspliced according to 250.24(B). Does anyone know you can do sets of main bonding jumper in parallel or not? Am I missing something? Its going to be wire not manufacturer provided bus or other manufacturer provided items I already inquired with designer
The code does not specify either way.
I do not see how parallel conductors equal a splice.
I see no issue with the parallel conductors, but if you do, mark the drawing up and send them back to the engineer.
I've never seen a 3000 amp servcie switchboard without a factory installed piece of bus serving as the MBJ.
agree. If it does not have a factory MBJ I would be suspect that it's not listed as service equipment
Engineer is the on who has shown 2 sets of 600kcmil AL. Engineer says they dont provide bus as MBJ
Curious how do you not see parallel sets of MBJ not a splice? They do have to connect together at ends how are they not splice?
It's two conductors terminated at each end. A termination is not a splice.
But I agree with the others. I've never seen any labeled as suitable for use as service equipment without a factory provision for the MBJ. At least, nothing under 30 years old. Is this new equipment?
Get out the red marker, cross out the two sets of 600's and add a note that the MBJ must be a bus bar equivalent to 1031 CM and send it back.
Since it (MBJ) is not supplied. Is the equipment service rated?
I just assumed it was since your installing an MBJ and stated main service switchboard.
A splice is a connection that extends the length of a single conductor, making it one longer conductor. A splice is between the two ends of a conductor. A set of parallel conductors cannot in any way be construed as being a splice.
