jbellino
- Central Florida
- Journeyman Electrician
Hello,
I'm dying to get to the bottom of something that has been puzzling me for a long time, in regards to bonding neutral to ground at the first means of disconnect.
Specifically, my question is about bonding the neutral to the grounding terminal strictly at the first means of disconnect rather than also bonding the two at the sub panel. I understand that the former works and what goes wrong when the latter is done (neutral return path flowing through both the neutral wire, the ground path, and everything bonded to ground). But I'm having some trouble understanding why this is.
We know that the power from the utility transformer travels in one big loop going through the meter, the service, the sub panel, the branch circuit, and all the way back in reverse order. So if the service (or first disconnecting means) is part of this entire loop going to and from the utility line, and all of the metal components in the branch circuits are connected to the service ground hub, which is bonded to the neutral, why wouldn't we also run into this problem of neutral current flowing through the grounding path/bonded metal parts here? I understand that current wants to return to its source. But both the subpanel and the first means of disconnect are upstream from the branch circuits, closer to the source. So this is confusing to me.
Hopefully the way I've presented this question makes sense.
Show less
Show less
