parallel 4/0 alum for residential 400 amp service.water pipe full size grounding elec conductor plus ground rod #6, if icome into first 200 amp panel with these groundig elec conductors how do i bond the second main breaker 200 amp panel to these conductors? Is this considerd a tap ? main bonding jumper? and where is it in the code. I see info on a main bonding equipment jumper on supply side and load side but maybe this is a different question but i dont work commercial and am not familiar with the reason why you would need one on the supply side, i thought you only had an ungrounded and grounded on the supply side. Thank you
