bub
New member
- Barnard, Vt USA
Large residential service with 400 amp fused disconnect. Feeders out of this into trough and then taps to 2- 200 amp distribution panels knippled out of top of trough.
Found a code in tap rules that says the tap conductors do not need to be protected if less than 10 feet.
Does this indicate you could save the cost of the main breakers in the 200 amp panels and go with main lug type?
