Main breaker for temp stand
Mustang125
New Hampshire
Master Electrician, Project Manager and Estimator
If you are installing a temp stand which has utility drop from overhead run down into the top of the meter socket, then from the meter socket to a temp panel (Talon #TL137US) directly below the meter, do i need to put a main breaker into the talon panel?
Your at 6 movements or less with the TL137US as it is.
I say no.
JAP>
It's for RV's mostly. Google it. I like the 6 movement idea but not sure if that right cuz I'm thinking it might be more of a protection issue, like protection for the panel sense it's guts are only rated for a certain amp. Or to protect from the cutout at the pole getting blow from a dead short or something that the branch breaker doesn't pick up fast enough. Not sure that's why I'm asking haha.
Jap is correct. See 230.71 and 230.72.
