Is it a 2008 code to must have a main breaker in a distribution panel ? I have a Disconnect with a proper lock out ( the bolted to breaker ) in a power plant and then would like to set a panel on the first floor of the building. Am I required to have a main CB. in the panel or will main lugs serve just as well what is the code requirement for this ? The old days you did not have to have a main CB as long as it was under six throws or if the disconnect serving the panel had a lock off means just checking to see if this is still okay. Thanks
