jetlag
- Eatonton, Georgia
I install a lot of 200amp 8/16 space outside disconnects .Often the inside panel is only 100 amp and fed from a 100 amp plug in breaker. The remaining spaces out side are used for a/c compressor , well pump, and sometime run a line inside for range. My question is what is proper way to label the 200 and the 100 amp breaker . One inspector flagged me because I labeled the 200 as service disconnect and the 100 as main . He wanted them the other way around .I did that next time and another ahj flagged me wanting the 200 as main and the 100 as sub feeder.
