I have a bit of a unique situation concerning a main breaker. What is being asked is to separate 2 sections of gear by removing the bus in between the 2 sections of a 480V 1600a GE Spectra gear. One section has the 1600A main breaker service disconnect and the other section is a MDP with multiple breakers. Engineer wants to take wires from the 1600A breaker to feed an ATS, then feed from the ATS back to the second section of gear that was disconnected. The transfer switch will be in sight of the service disconnect, I am concerned if the second section of gear we are re feeding out of the transfer switch will now need a main breaker installed?
