whackit
- Los Angeles, CA
Hi Folks,
Both me and my electrician (Im a GC) are scratching our heads on this one. I thought I would give a try here before I have to start the expensive stuff...
Here's the situation.
325 Amp service panel (CA style main panel with just two main breakers in it) feeds 2 Sub panels in seperate buildings. Main breakers Rated at 100 amps and 200 amps at service entrance panel. These then feed (wire correctly sized, actually oversized to allow for expansion on 100 amp leg) a 125 amp sub panel in garage building which has a 100amp main breaker, and a 200 amp sub panel in main house. Everything is wired correctly on the panel level, separate grounds and neutrals at subs, no connection between buildings etc. Professionally wired by licensed electrician I have used for the last 10 years.
Here's the rub, we had a circuit in the garage (100 amp side) that has a short, not sure if it is to ground or neutral yet. When the 20amp breaker throws... It kicks the main 100 amp breaker at the service entrance. It does this every time. We cant figure out why a 20 amp short is throwing a 100amp main. It will do this if everything else on that panel is disconnected. Just to test we overloaded another circuit to see if it was specific to the shorted one and it also kicked the main. Everything seems fine between the sub panel and the main... It's only like a 35' run.
Any Ideas?
Any Ideas?
