Re: Main breaker vs. Main Lug
You never need a main breaker, if the sub-panel is in the same building. It's a design choice.
However, if the pool is in a separate building, then the separate building itself would require a disconnecting means. Using a main breaker in the panel would be an easy way to achieve that.
