JoeStillman
- West Chester, PA
If the main breaker in a switchboard is bolted to busbars that are drilled for compression lugs, can I use the 90°C ampacity rating for the incoming cables?
That's a question for the switchgear manufacturer and also where they terminate on the other end.If the main breaker in a switchboard is bolted to busbars that are drilled for compression lugs, can I use the 90°C ampacity rating for the incoming cables?
