trojans4
- Iowa
- Semi -retired master electrician. Fully retired math and physics teacher.
100A main breaker (bolt on with lugs) in Square D Homeline box. I am sure the main breaker is defective but thought I would check to see if there were any other possibilities before I bought a new one. All breakers powered by one hot wire read 122V from load side to ground and all of those circuits are working. The breakers powered by the other hot wire all read around 30V and those circuits obviously are not working. When you turn the main breaker off and on several times the 30V breakers will read 120V for a time and those circuits are working(sometimes for several hours) and then go back to anywhere from 0 to 30V. I don't think there could be a loose/broken neutral problem since that usually means the other half of the circuits are reading high like 180V to 200V. Any other ideas besides a bad main breaker.
