wirenut46
- United States
I have a service 480/277 volt three phase. I am setting a 400/amp 3 pole main circuit breaker in a nema 3 r enclosure outside under the gutter with a ct cabinet. My wire size going into the building is 500 kc mil. I want to set a 400 amp panel 277/480 inside 80 foot away. My question is do i need a main breaker on the 400 amp panel inside it will be used for the warehouse lights that are 277 volt. I will also be feeding a transformer 480/277 to 120/240 to feed a panel up front for the office area it will be 120/240 200 amp. Do i need a disconnect at the transformer feeding the 120/240 volt panel and does it need to be a main breaker.
