Grouch
- New York, NY
Hi all,
We're looking at possibly re-routing 4 sets of conduit and wire (from a 1200 amp switch). The 4 sets feed a commercial building... they punch into the building underground (the 1200 amp switch is outside the building in another structure) and continue for about 200 feet inside the building until they go into the switchboard serving the building. On the ground floor of the building, in the area where the conduits are underground, there will be a new large pool installed. We're looking at either re-routing the conduits around the pool (keeping them underground), or routing the conduits overhead tight to the ceiling (above the pool). The new conduits will be rigid metal conduit. Is there any concern with corrosion if we go overhead? I know it's RGS conduit, but where i worry is that the feeder serves a whole building, and am not sure if it should be exposed to a pool environment. There is a dehumidifier for the pool. Not sure if my concern is valid, looking for feedback.
Thanks!
Thanks!
