EBSoares
- McKinney, TX
- Electrical Engineer
Hi, all.
Trying to determine the need for MCBs for downstream panels of the same voltage as their parent panel (say, a 480V panel feeding another 480V panel). From my understanding, the NEC does not require an MCB on the child panel in this scenario, if it has a circuit breaker in the parent panel, so I do one of the two below:
As a specific example, we have a 480V, 2000A switchboard being fed from a 480V, 4000A switchboard, both really far from each other (around 1,000 feet) – should the 2000A switchboard have an MCB? This MCB might add a huge cost to the project...
Thanks in advance,
Edgar
- If the child panel is in the same room, I make it MLO (main lug only).
- If the child panel is in another room (specially if it’s a room far from the parent panel), I provide an MCB, so they don’t need to go hunting for the parent panel to turn off power (I guess this could be considered "safer")
Thanks in advance,
Edgar
