I am a new inspector trying to become more proficient with the 2017 edition of the NEC, so please correct me if I use any terminology incorrectly.
Backstory: Homeowner installed a 3 wire system to feeder panel in a new detached garage. A few weeks prior to this photo (when I was inspecting framing) he had both hot wires (6AWG I believe) going to the main disconnect breaker. The neutral wire (now seen being used as an equipment grounding conductor was on the main bonding jumper above. The other ungrounded conductor is now marked as use for being a neutral wire. The homeowner states he is only going to have 110 volts in the garage. I have written up 250.32(B)(1) stating an equipment grounding conductor shall be run with supply conductors and be connected to the building disconnecting means. Is there another code section stating that the main circuit breaker is not appropriate for a 110v install? My concern is a jumper being placed to the other breaker terminal so all breaker slots can be used. Input is greatly appreciated. I could not figure out how to upload an image of it.
