Main Disconnect Height
seabeece
Where can I find the minimum distance a Main Disconnect (100amp Outside)may be off the floor? I found the maximum but not the min. Jokers pulled and cut wire to short and I need a quick fix.
Re: Main Disconnect Height
There is no minimum per the NEC unless it is for a mobile home.
Some local jurisdictions have minimums such as not less then the maximum flood plane. Check with your AHJ.
Local power companies around here spec 5.5' to the center of the meter. We've had instances where we've had to pour concrete steps under a meter to meet this.
No NEC code that I know of, except 6'7" max for switches (Art. 404).
