My question is on having two disconnects for a industrial machine. One disconnect will be for auxiliary outlets (200amp) and the other disconnect will be for rest of the machine (800amp - motors, heaters, etc.). The disconnects will be side by side in the cabinet.
Can I supply the two disconnects with one feed where the 200amp disc. can remain energized with the 800amp disc. off and vise versa? In other words jumper the line side of the two disconnects.
In the past we normally have a separate feed for each disconnect. Maybe this is a NFPA issue?
Thanks
Rob
Thanks
Rob
