As shown in the attached figure. This is a main 400A breaker disconnect switch. Typically for something like this i typically see fused switches or a boxed circuit breaker. In this particular case, since the disconnect handle kit is on the breaker handle - if a short occurred will the handle switch on the breaker leg cause it from tripping correctly? Thank you
