Saturn_Europa
- Fishing Industry
- Electrician Limited License NC, QMED Electrician
I have damaged and loose wires on the main engine ECM. These wires need to be cut back and re terminated. Has anyone terminated a box that looks this?
The wires are stranded 14 gauge. One popped out when I was inspecting it and I pushed it back in and it seems to be holding.
How do you remove the wires that need to be cut back? Is there a release? Just push a small screw driver down next to the wire?
What happens if I remove the allen screw? does the block pull off exposing pins? Is there a special pinning tool?
