goldstar
- New Jersey
- Electrical Contractor
I'm just looking for an opinion here. I've been installing whole house generator ATS's and, as luck would have it, I have one installation where the lugs in the existing main breaker panel are so corroded that I can't get the feeders out. Even if I could I wouldn't want to install the new feeders back into it for fear I'd either snap off a lug or it wouldn't tighten down. So, I have to replace the panel. My question is, should I re-install a new main breaker panel (separating the grounds and floating the neutrals is understood), or should I use a main lug panel ?
Here's my thinking......There are often times when a homeowner, tradesman or even the fire dept (in an emergency situation) wants to shut down the service at the main breaker. If I use a main lug panel after the ATS and if the main breaker is shut in the ATS, the generator would kick on. So, that would mean they would also have to also shut off the generator. On the other hand, if I re-install a main breaker panel they could shut off that main breaker and would be assured that none of the branch circuits would become energized even if a power failure occurred in the interim.
Any opinions would be appreciated. Thanks.
