There is existing 90KVA Dual Output Frequency Converter at 208V 3P 4W.
The Name Plate Rate on the Input FLA is at 287 Amps at 208V. The equipments internal Main Circuit Breaker is fully rated at 400 Amps. The customer wants to feed the Frequency Converter with a 300 Amps from a 600A Main Distribution Panel.
Does the NEC permitt you to feed lower amps to this Frequency Converter.
If not, reference code section.
