200 amp panel, all conductors in romex. All neutrals tied into the neutral bus and all the grounds tied into the panel grounding bus. Jumper was removed from the neutral and ground bus. Bonding screw is in the neutral bus. Panel bonded with jumper to bushing on conduit from meter. Grounding bus also tied to water pipe.
Ground and neutral conductors are isolated from each other. Is this set up kosher?
