Main Panel used as a sub-panel
delpi
New member
I am trying to understand more about grounding and neutrals. I understand that while the ground and the neutral can be connected to the same bus on the main panel, they must be separated at a sub-panel.
My understanding is that this is done to keep neutral current off of the ground wire between the main and sub panels. That makes sense.
Our situation is that we have a meterbase/disconnect on one side of a block wall, and a panel on the other side. They are tied together with 2 inch rigid conduit.
I'm having a tough time understanding why the conduit doesn't, in effect, make the meterbase/service panel one unit and why in this situation the panel is treated as a sub panel.
Part two of my question - The panel is a standard 200 AMP 40 opening Square D QO panel. I've not used one of these before as a sub panel. It appears that I can't separate the neutral and grounding busses so I need to install an additional grounding bus and bond it to the panel.
Am I understanding this correctly?
Thanks,
Dave
Dave your profile says retired. What have you retired from? You'll need to fit into this criteria for us to provide you with the answer to your question:
This site is designed for:
Contractors
Electricians
Engineers
Inspectors
Instructors
Other electrically related individuals
* This NEC? Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
