Gregstarke
- San Lorenzo ca usa
Any clues as to how I can look for manufacturer or the bus rating, the tags are long gone, but this setup has been in for years, still do not want to overate the bussing if someone slipped a second 100 amp on to a 125A busbar? The 2/0 tells me it should be 200 but I need to do some detective work.Hard to tell for sure. Right now it is a 200 amp setup but the panel may be rated higher. I am guessing it is not any higher than 200 amps.
Fed by #2/0 but no label AHJ questioning rating.View attachment 20677
Probably some off-brand meter pedestal mfr, like Midwest. Myers Switch in SoCal used to sell them up here too, as well as Delta Switchboard out in Stockton. Delta is out of the business, Myers is doing different things now. But for a while in the 70-80s those companies made Meter Pedestals, with or without mains, because of all of the different USERC and local requirements being difficult for the big national suppliers like GE, Sq. D, ITE and Westinghouse to keep up with. Over time the big boys caught on and the small local suppliers died out.Any clues as to how I can look for manufacturer or the bus rating, the tags are long gone, but this setup has been in for years, still do not want to overate the bussing if someone slipped a second 100 amp on to a 125A busbar? The 2/0 tells me it should be 200 but I need to do some detective work.
