I am in the process of feeding a main house panel from a 400amp split with two 200amp breakers. The Main house panel is 60' away from the main meter section. The main meter section has a 200amp breaker feeding distribution & the feeders are going to be connected to the separate 200amp breaker. Do I need an isolated neutral conductor/ buss bar at this point or can I bond to the ground and can & isolate after this point? Thanks for your help.
