jport
- Akron,Ohio
I am bidding a job where i am trying to calculate the main feeder wire size.Ther are a total of 5 meters.The supply voltage is 120/240 single phase. I have (2) 200 amp commercial bypass sockets (200 is mininum commercial amperage) One of the 200 amp panels is basically an office with not much load at all,other than maybe 10 outlets probably on about 4 20 amp circuits and 2 lighting circuits.The other 2oo will have more load on it with a 5HP air compressor.50 amp welder outlet and about 15 20 amp receptacles on about 5 circuits and a couple lighting circuits.The other 3 meters will be 100 amp for 2 small apartments and a 100 amp meter for a house panel that probably won't be used but i am putting it in for code purposes.So there is 700 amps of potential but the whole system MAY pull 200 amps total max.Any help would be great Thanks
