Time for the rest of the story.
If the batteries are literally blowing up, then there is definitly something more going on here than just the wrong type of battery. Need to go back to the generator company and find out what does the generator manufacturer specify for their starting batteries.
Off the top of my head, the symtoms match a battery charger system that is always charging the batteries. Once the battery has reached full charge, it then starts turning that charging current into heat which cooks the electrolyte and also starts turning the water in the electrolyte into hydrogen and oxygen gas.
If you do go to conventional flooded cell batteries, I suggest you get those catalytic caps for the cells. These caps have a catlyst inside of the vent tube that will cause the hydrogen and oxygen gases to recombine back to water that then drips back down into the battery cell. Will save your batteries if you overcharge them, and greatly reduce the amount of adding of water you need to do.
Read about them being used on a mountian top radio repeater site, where the site is only accessable by ground for a few weeks in the middle of the summer. They added these catlyst caps to their batteries and reduced their water consumption in the automatic battery watering system to something negligable.
