It is a common problem that bus ducts from power or distribution transformer secondaries connected to medium or low voltage switchgears suffer catastropic failures due flashover cause by water or moisture ingress as well as dust. The common solution that we do to avoid this problem is to open these bus ducts for inspection , maintenance or cleaning which is time consuming and sometimes only disturb the bus insulation integrity which also causes voids and then cause partial discharge. Now my question . Is there a way to monitor these bus ducts to avoid some of these time consuming but also neccessary maintenance issues?
I would surely appreciate some good ideas folks. Thank you.
