I’d replace along with maintenance getting a stern talking too.Maintenance sprayed WD-40 in a bunch of receptacles in and out of a commercial building, some are GFCI's. Should these all be replaced? Some are not working.
Thanks and good info!The WD in WD-40 stands for "Water Displacer" (40 is because this was the 40th version of the formula), it is SPECIFICALLY suitable for use on electrical devices that may have gotten wet, because it makes the water molecules separate and not be able to conduct. If you ever get in a situation where your car engine gets wet and dies, WD-40 can save the day.
It is totally inert with respect to electrical components and insulation. It is flammable in a gaseous state, so WHILE spraying, AND there is a spark for ignition, so it is always best to KILL POWER before spraying, but once it has been sprayed, there is little risk of ignition. I wouldn't get worked up over this, in fact I recommend it to people all the time, especially around the holidays when they have string lights causing GFCIs to trip. I just tell people to turn off power first, and in this case it's possible they did.
Probably uses butane as a propellant. That's what is flammable.It’s definitely flammable in aerosol state. I’ve used it as a flame thrower to destroy wasp nests.
Maybe TR receptacles? Think I'll try itwas there reasoning behind blasting them with WD
If your getting smacked around, pull out a zippo and the WD-40! There's more than one kind of wasp nest...Being a maintenance electrician , I'll view this post as a tiny win since we usually get a good bit a smacking around on the forums.![]()
Moving / replacing equipment that had been in place a long time in a high humidity area, stuck twislocks, corrosion, difficult plugs and paint on receptacles (apparently removes the paint). There also are some of the newer GFCI's and WR receptacles that are TR style and were giving them trouble.What was there reasoning behind blasting them with WD-40?
Yeah I have a heck of a time getting my meter probes in sometime. LmboMaybe TR receptacles? Think I'll try it
Get you one of those adapters for 2-prong receptacles so a 3-prong plug can be used. Put your meter leads in the adapter.Yeah I have a heck of a time getting my meter probes in sometime. Lmbo
So then the answer to that is no.my concern was it would degrade the plastic or leave conductive residue.
Makes the hotdogs slide down easier!My brother in law catches catfish using pieces of hot dogs soaked in WD-40 as bait. I wouldn’t have believed fish would eat that if I hadn’t seen it myself.
It will degrade rubber. Ask me how I know!So then the answer to that is no.
I've heard that before, never tried it. I have to imagine that unique smell of WD-40 might permeaet the fish.My brother in law catches catfish using pieces of hot dogs soaked in WD-40 as bait. I wouldn’t have believed fish would eat that if I hadn’t seen it myself.
