we did a major mistake, we went according to plans, paco did not give us permission to operate for a solar project, We do not have a visible disconnect Southern California Edison wants to see that the disconnect is in the open position,rackable breaker or knife blade disconnect, 480/277 volt 1600 amp new service only for solar, there is for cabinets #1 is the pull cabinet for paco then 2 is meter and main breaker 3 and 4 are distribution, the idea is to put a disconnect on the side of the last distribution cabinet, we're gonna disconect the bussing except for neutral from cabinet 2 which is main breaker from cabinet 3 We plan on hooking up cabinet 2 to line side of disconect via wire 5 sets of 400 mcm with 4/0 equipment ground no neutral, then hooking up cabinet 3 the same way on the load side of disconect, my question is when we installed switch gear I don't remember seeing accommodations on bussing for taps, I know if I drill my own holes it would not be UL listed anymore but I have no choice, does anybody see anything wrong with that install,
