moonshineJ
- USA
A 1500 VA UPS works fine while on normal power coming from the utility or from the service diesel generator. If this power secured (either the utility line breaker or generator breaker trips), the UPS works correctly, providing backup 115 VAC to loads plugged into it. The only scenario in which the UPS does not work is when generator is secured using the remote shut down pull handle, which secures the fuel to the generator (this not a normal generator shutdown, which opens generator breaker first and then shuts the engine). It takes maybe about half a second that shut fuel slows down the engine, and the generator breaker is tripped by undervoltage relay (UV). For some weird reason the UPS cannot distinguish between these two conditions. It doesn't "recognize" decaying voltage (even this happens in a less than a second!), and just shuts itself down.
We reviewed a few options (e.g. followed the manufacturer's tips to change some hardware and software settings; no luck..), but here is what I'm looking for in particular.
Is there any outlet plug-in device or maybe a hardwired standalone module, which upon sensing decaying voltage (when generator "choked" on fuel, voltage decays from 115 VAC to maybe 80-90 VAC, before the UV trips generator breaker) would shut power to UPS immediately? Say, something quick-acting, which would trip power supply to UPS may be at 105-110 VAC?
Any help would be greatly appreciated.
