dedbrk
- Washington
I need some help. -Situation- "Multiple occupancy building with four tenants. All four tenants are under the same roof and inside the same structure. 2 hour fire wall seperates tenants down the center, two suites on each side of the fire wall. One service hits the exterior of building with one main disconnect. One 200 amp sub feeder goes to each tenant space from the exterior service, including penetration of firewall"-. Local AHJ is mandating a seperate and additional service for the two suites on the other side of rated wall. In short, one service for each two tenants. It is my understanding that you can do this if you wish due to the 2 hour wall which technically makes them seperate buildings, but it is not mandated. I know when you have two services in this manner there is certain rules to follow in order to proceed, what I didn't know was how it can be mandated. Any help in this matter would greatly be appreciated. Has anyone else had something similar happen to them?
