Not if its got a really big lid!iwire said:If it is really 6' x 6' x 6' it appears you will run into 110.26(E)
charlie b said:
Not if its got a really big lid!:grin:
charlie said:I was only thinking about the possability of water in the manhole since we have to pump ours dry on a regular basis to get down into them to work.![]()
We see it here in Colorado quite frequently, of course were usually, about a mile above sea level too. As long as its sealed dry location, I wouldn't think there would be a problem, accessible, versus, readily accessible.:smile:JOHNNIEB said:It Is 6'x6'x6' And It Is To Be Water Proofed And Have A Gasketed Top. Now I Know That It Will Get Some Water In It But It Will Have A Sump Pump Along With A High Level Alarm. Does This Make A Difference.
NEMA 3 would not cut it for rising water, NEMA 6P would have to be used. :smile:mxslick said:I'd be sure to use NEMA 3 rated gear to help protect against moisture, . .
charlie said:Sorry, I didn't notice the pump and alarm.![]()
