sfav8r
- San Francisco Bay Area
We have a client that has been told by the city that their heat may be inadaquate (it's a rental unit). The unit is about 700-800 square feet and there are three electric wall heaters that are each 1500 watts.
The citation says that the heaters must be able to heat the unit to 68 degrees. Well, It seems to me that this isn't enough information. If it is 65 outside, I'm sure the heaters will easily heat to 68. It also says nothing about how long it can take to get to 68 degrees.
Is there some standard calcualtion for this? I found something on-line called a manual "J" calculation but I have no idea how to do it.
Any help would be appreciated. I basically need to caclulate the required heat for this unit then determine if the existing units are OK or if we need to upside.
Thanks
Thanks
