Some at that small size have their own built in thermal protection.You need overload protection 430.32(D) > 430.32(B)
No and no. The disconnecting means and the motor controller are the same thing in that case.That's what I thought but if the fan was provided with internal overload protection as part of the fan do we still need the starter? How about if we have a fused disconnect switch where the fuse is sized at 125% of the FLA to provide overload and short circuit protection, would a starter still be required?
Can a disconnect switch be used as On/Off operation for 1HP , 480V-3-Phase cooling fan (fan model number: AIRMAX AM-30GP) or we need to provide a manual starter with overload protection? I thought this fan came with controller but that wasn't the case.
Thanks in advance
:thumbsup:Start by looking at the actual motor nameplate. If it has internal thermal protection, it MUST say so, either with words or sometimes it is abbreviated as "TP" with or without numbers after it.
If you don't see anything showing that it is thermally protected, you must assume it is not and provide it externally. Fuses can technically be used, but it isn't a good idea.
