Whats the difference in a Manual Transfer Switch an a Double Throw switch?
A double throw switch is a 3 position switch. A manual transfer switch is an example of a double throw switch.
A single throw switch has 2 positions. An example would be a light switch.
You can, as long as it is otherwise qualified. Under some circumstances a TS (either ATS or MTS) will have to be service rated. A typical double throw switch will not be. It has to meet all of the requirements for a disconnect, etc. I think.So you cannot use a double throw Center Off Switch as a transfer switch
Not per any manufacturer's data that I have seen.So you cannot use a double throw Center Off Switch as a transfer switch
The service entrance rating is only part of the problem. The center off position has little to do with it also. A double throw switch is not rated to switch between two live sources. The issue is primarily the management of the source to source arcing.It should work fine in practice, ....
SqD DTU361 Series F, "UL Listed as suitable for use as Service Equipment." Pag3 3-14 Digest 173 October2003. Dated cataloge but I just bought it for this purpose last year.
