Fitzdrew516
- Cincinnati, OH
Recently I had designed a 3000A service to a facility. I included GFP on the main gear per code, but recently there have been some changes in the field that I want to clarify. The contractor and the client have put forth a plan to install a manual transfer switch outside the building right before the conductors enter the main gear. Questions below -
1) Does the transfer switch need to have GFP? I assume it will have to incorporate this now if there is a disconnect on the transfer switch considering that would technically be the service disconnect now.
2) The contractor had selected a 3 pole transfer switch. I know there is some give and take as to which is better: 3 or 4 pole. Does anyone have any input as to why we should go with one that disconnects the neutral as well?
Thanks,
- Drew
Thanks,
- Drew
