I have a cut sheet for an electric pool heater, it says 50A CB and #8 cu wire for branch circuit. I do not have the actual total nameplate load for the unit in front of me. If in fact the total load is 50A, won't I need to install it on a 60A CB w/#6 wire per NEC.If the total nameplate load is 40A, then the #8 and 50A CB would be ok, am I figuring this correctly? Thanks.
