Paulie15
- Sutton, WV, USA
Hello, I am currently working with a local marina to bring up to state mandated regulations, and article 555. Their current service consists of 35' utility pole with 2 side arm disconnects mounted below transformer supplied by the corps. of engineers. The disconnects are mounted so high because of flood plane, and operated with a cable and pulley system from ground level (one cable opens, one cable closes). Each disconnect is feeding a type W cable that extends down and out to dock distribution panels. Is this an acceptable installation? The corps. will not allow them to build a crows nest or platform with a ladder. To top it off I need to find a way to achieve a minimum of 100mA gfi protection for these cables. Any help?
