Marine Electrical Safety
safspir
New member
Hi folks, "Heard" about an interesting possible electrical safety hazard today. This was at a shipyard (saltwater) where work is performed on vessels moored at a pier. The shore power for the vessels is 480. This is supplied by a Square D SE series breaker, 1200 Amp. This in turn fed multiple sub panels. Problems started with recurrent ground fault trips on this main breaker. This happened during unusually high tides or very rainy and windy weather. During the high tides, stainless boxes with ocal conduit were submerged. To try and troubleshoot the problem, 2 electricians were dispatched out in an aluminum skiff with no PPE in pouring down rain conditions. They were to open up the boxes and inspect them after the tide had receded. All circuits were still energized. Their shop safety rep noticed what was about to transpire and lodged an immediate complaint. His reasoning was that if another ground fault were to happen while one of these workers was touching the stainless box, there was a chance of electrocution. (All paths to ground). He felt that the breaker reliability had been compromised, and even if it had not, injury could happen before the ground fault protection took effect. One worker argued that if there were no connections in the boxes (that they were used as pull boxes), there should be no hazard. Well, long story short, the safety guy prevailed, after reminding management/supervisory staff of certain regulatory/liability issues. So, anyone have thoughts on this?
Given that the wiring was known to be compromised, not necessarily at a junction but possibly skinned wires near a pull box, there is no way I would consider opening an energized box under the circumstances.
I would consider even when the circuit is provided with GFCI, still even when there is no current in the circuit, people could die while working under the above circumstances due to hysterical effect-just out of fear of electrocution!
