Working on a project with a boat yard, they have pedestals as well as custom made charging stations. The voltage in the building is 208-3. The issue is that a lot of the appliances and loads in the boats require 240v. We will have panels that feed these pedestals and I was thinking about putting something before the panel to increase the voltage from 208>240. Not quite sure on the KVA yet. Wanted to get some opinions on whether I should increase the voltage before the panel (or) after on each circuit. Any opinions on this, and suggestions on what I should be using?
What exactly are they?
Many motors are rated 208/230 meaning that either voltage will work and resistive equipment will work fine on 208v, granted at 75% power. It's still 120v between phase to neutral, so if the controls are 120v, they work just fine.
I'm not sure how much portion of total load the pedestrals the boats represent and how they're wired, but in worst case, you will need three single phase 208v to 120/240 center tapped transformer. If they're spread out evenly across the phase, you can't just dump every load onto one phase.
I'm not sure about the legality of using an auto-transformer. While you can get 208v to 240v, it's more complicated when you have to make sure you have 120v between neutral and either hots and that neither hots are floating more than 120v with respect to ground.
Since the 208v service is phase-to-phase, you can't say do something like this:
L1/O1-----C----L2---O2
L=line
O=output line
If L to L is 208v, you will have 120v between L1/O1 to C, and C and O2, but the problem is that "C" won't be at the same potential as the service ground, so you can't just tie that to ground.
Leaving the 120-N-120 with the whole thing floating above ground is absolutely not permissible.
So, it looks like you're gonna have to sucker up for isolation transformer.
I'm not sure how much 120v you have, but do you suppose you can get the utility to convert to 240/120 Delta?
