Marine Question - Xfmr and Ground
Designer69
Working on a marine project if anyone here has some marine experience.
Question 1: (See attached Pic).... the Upstream xfmr is shown Delta/Wye and the downstream transformer is delta/delta. does that work or should the downstream xfmr be Wye/Delta?
Question 2: (See attached Pic)...How come they use the "HRG" High resistance ground on the Switchboards instead of just typical earth/ground rod?
Thanks
View attachment TempUntitled.pdf
