bullheimer
- WA
i just want to give you guys a heads up, that when installing these guys' heaters you are going to have to run the home run TO THE HEATER, despite them selling you THEIR OWN Line voltage thermostat that looks like every other line voltage thermostat i've ever seen, complete with Line and Load marked on them. If you run the wire to the stat first you will risk burning up the unit (if over 1000W) as they say "the fan must run after the heater shuts off or you will burn up the unit!"
i am having to remove the heater can, to my 4Kw unit, (which, thank God, is big enough for me to fit thru), and run a new wire from the heater to the stat because of this. Same goes for the QMark 2 KW heater i have in the ceiling. And NO the Directions DONT say to do this, they said their wiring diagram shows this, but is it borderline worthless, not showing any line in wires other than from the stat.
And if that isnt enough, the wire entering the QMark heater can is within an inch of, and above, the heating element!!!!!!!!!!!!!!!!!!!!!!! no way to move them. what a joke, i hate these guys. jmtc's. "this bar will be closed in three weeks and that's alright with me".
