Masonry boxes in sheet rock/studded wall
JJWalecka
New England
Is it legal to use a "masonry box" in a sheet rocked metal framed wall? Obviously it's not a "masonry " application but I could use the extra cubic inches
Extra cubic inches compared to what? A 4 11/16 box with a mudring has a lot more fill. If you are talking about a single gang masonry box. Also, you are asking for trouble. Setting the depth of the masonry box on rough in is a pain and usually has about a 20-30% rework percentage once the sheetrock goes on. A 4S or 4 11/16 box with a mudring has many bracket options to set the boxes right. Masonry boxes are also expensive in relative terms.
As Eletrofelon stated the masonry box can a good option when you need more than 2 gangs.
i use them all the time when needing a 3g or more. Like that they maintain their outside dimensions as opposed to plastic nali on's
