ahawkscry
New member
- Billings, MT
Upon troubleshooting find this break in the circuit, I found the the main bathroom in the home which was built in 1962 to have the whole Master Bath on this same circuit as the Main Bath, but is tied in on the load side of the GFCI Outlet, The Master Bath doesn't have a GFCI Outlet in it's own room on the vanity next to the switchbox where it source of power is tied into. I know from the past where two GFCI outlets can trip each other out, when the second one is connected to the load side of the first GFCI.
My question is. Would you remove the first GFCI outlet, replace it with a standard outlet connected by pigtail, and replace the complete 20A circuit breaker for a GFCI Fault Protecting Breaker. or what are your thought's?
