Joe Rocker
Here’s a situation I need help with. Son in law was putting in new bulb holder with a pull string in master closet. He said he hit neutral wire with his screwdriver and there was a spark. As of now, no power (light) in master closet, master bedroom has 2 receptacles out, light in master bathroom and gfci in master bathroom not working. The light in the master bedroom does work. I checked all the breakers in the panel, reading 120 volts but wire coming down from the ceiling in closet has no power.
The master closet, definitely 14g wire and the gfci in the master bathroom is using 12g wire. It’s a double gang box in the bathroom with a single pole next to the gfci. I know a little bit, but running out of things I can do. One more thing, he said when this occurred, he never had to go out and reset a breaker
