Re: Master Electrician License?
Originally posted by jaxx: Just what is the difference between an Electrical Engineer and a License Master Electrician. . . ?
Four years learning ?Why,? as opposed to four years learning ?How.?
Not all projects require ?engineering,? but all require that decisions be made. The person responsible for a decision is the person who made the decision. But to clarify the use of our terms, no person is permitted to offer ?engineering services,? unless that person is licensed as a ?Professional Engineer? by the state in which the installation (not the design work) will take place.
It is a question of fact and a question of local rules, as to whether a Licensed Professional Engineer will be required to make the design decisions, and to sign and seal the related plans and specs. In general, if one company prepares the design and a different company performs the installation, you need a PE. By contrast, a Design/Build company can often make all the design decisions, and can perform the installation, without consulting with a PE, and without obtaining signed and sealed drawings. By contrast again, some cities and some types of facilities will require signed and sealed drawings, even if the design and construction are by the same company.
Doesn't the Electrical Engineering then become the responsibility of the Master Electrician?
No. If there a requirement that electrical engineering be performed, then the work must be done by an electrical engineer who is a licensed PE, and that person becomes responsible for the design. Please note, however, that if the Master Electrician does not build the exact thing that the PE designed, and does not get approval from the PE to make the changes, then the Master Electrician takes on the responsibility for the changes.
